Lobby Ambassador - Automatic deletion from WCS after Expiry or Account
Answered Question
Apr 23rd, 2008
Hi Guys,
When I create a guest account and the account time expires, the account still remains on the WCS (but not on the controller).
Is this a feature of the WCS or a bug?
If so, can I ask the WCS to automatically remove all guest users accounts from the WCS lobby ambassador either directly after expiry, or say at 00:00 hours every day?
Many thx
Ken
Correct Answer by sridhar_123 about 8 years 8 months ago
Hi kfarrington ,
This is new feature in WCS. Not a BUG.
Thanks and Regards
Sridharank
Overall Rating: 5 (1 ratings)
gmarogi Tue, 04/29/2008 - 08:02
The maximum life time of guest user is 30 days. Account will automatically be deleted after 30 days. Any value over 30 days will be set to the maximum age of 30 days.
kfarrington Tue, 05/06/2008 - 07:40
Hi there,
Many thx.
The way I understand it, is that yes the user expires, but you still have to clear down the username off the WCS periodically.
Just thought the WCS may be able to do this as the timer expires but had a chat with a few guys at Cisco and is not possible currently.
Cheers
Ken
krengasw Sat, 05/31/2008 - 10:26
Hi ken,
when guest user account expires,we need to remove guest user manually from wcs.
It is a feature of wcs.Not a bug.
No,you cannot ask wcs to remove automatically guest user once expired or specific time.it is not implemented to remove automatically or scheduled interval.
Kannan
Correct Answer
sridhar_123 Mon, 06/16/2008 - 06:13
Hi kfarrington ,
Thanks and Regards
Sridharank
krengasw Mon, 06/16/2008 - 08:15
Hi Ken,
could you please mark this issue as re-solved so that future readers may benefit from our collective intelligence.
you can expect automatic removal of expired guest account in coming releases of wcs.it is a feature of wcs rather bug as of now.
Kannan
kfarrington Mon, 06/16/2008 - 08:21
Sure will.
Many thx :))
Good work btw guys. The WLAN stuff is impressive :)
All the best
Ken
Trending Topics - Security & Network
