Xml Application for a different Locale
Answered Question
Apr 23rd, 2008
i have call manager 6.0 and phone sets 7942 , 7940 and 7911
i am trying to develop arabic xml services on the phone i have already installed the arabic locale on the call manager and my 7942 set is displaying arabic interface now for everything on the phone except when i am trying to send arabic text
i have these lines at my code :-
Response.ContentType = "text/xml";
Response.ContentEncoding = System.Text.Encoding.GetEncoding("utf-8");
Response.Charset = "utf-8";
CultureInfo ci = CultureInfo.CreateSpecificCulture("ar-SA");
Thread.CurrentThread.CurrentCulture = ci;
Thread.CurrentThread.CurrentUICulture = ci;
also the http header returned from the phone is
{Connection=close&Accept=x-CiscoIPPhone%2f*%2c+text%2f*%2cimage%2fpng%2c*%2f*&Accept-Charset=utf-8%2cISO-8859-1%3bq%3d0.8&Accept-Language=ar_SA&Host=10.64.14.13&User-Agent=Allegro-Software-WebClient%2f4.34&x-CiscoIPPhoneModelName=CP-7942G&x-CiscoIPPhoneSDKVersion=6.0.2&x-CiscoIPPhoneDisplay=298%2c144%2c3%2cG}
so the telephone is accepting arabic language but displays it as small question marks inside squares
if any one can help please.
Correct Answer by stephan.steiner about 9 years 3 months ago
Do you indicate which character set you're using when sending the message? I'm not sure if it really makes a difference, but I'm always sending the following xml before any CiscoIPPhone elements:
out.write("<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>\r\n");
ISO-8859-1 is Latin1 and covers the locales we commonly use in Europe. I figure in your case it would be something else - probably UTF-8 since that's what you sent your character set to when formulating the response.
Overall Rating: 5 (1 ratings)
Correct Answer
stephan.steiner Wed, 04/23/2008 - 08:27
  • Silver, 250 points or more
