Unable to dial 0807 numbers from Seoul in Korea
dezoconnor Wed, 04/23/2008 - 02:33
  • Silver, 250 points or more
Are you striping the .9 on the route pattern? Are you seeing anything hit the voice gateway? Try calling the number again and run a debug dialpeer.
dezoconnor Wed, 04/23/2008 - 02:44
You probably can't do this during working hours but just check to see if the route list is registered and reset it, this should in turn reset the voice gateway. What happens if you do a csim start xxxxx (number you're trying to dial)?
dezoconnor Wed, 04/23/2008 - 03:04
lol, the options are getting thinner!
- I'm assume that a debug voip ccapi inout produced no results on the gateway?
- Run a detailed trace on the cucm and see whats going on there.
As a last resort reboot the vg and restart the ccm service.
