How to upload IP Phone Service to CCM6?
Apr 23rd, 2008
May you all be in peace!
I have developed an IP Phone Service, and after having hosted it on a server, gave its URL in CCM6, working great.
But I dont want to have an extra server. Is it possible to upload this IP Phone service on the CCM6 box?
Thank you in advance!
Mudassir
msabir Wed, 04/23/2008 - 05:22
  • Bronze, 100 points or more
You can probably find your way to host IP phone service on CCM6 but it is not recommended and approved by Cisco. It can get you in trouble with the support. This is one the reason in CCM 5 and above Cisco has sort of locked down on direct access to the OS and web server admin on CCM. In v4.x you had full access to Windows OS, IIS and SQL Server 2000.
Sushil Kumar Katre Thu, 04/24/2008 - 01:17
  • Gold, 750 points or more
Hi Midassir,
As far as I know, its not possible to achieve this on UCM 6.x.
My be you can find out some workaround. But in that case you won't get the support from Cisco.
However with UCM 4.X or earlier its very well possible. Even I did this on one of the LAB setup.
-> Sushil
