CCM 6.1 and CUE 3.2 inteoperability
Apr 23rd, 2008
Hello, I am looking for a guide on how to install and configure CCM 6.1 (or 5.1) and Cisco Unity Express 3.1. I looked in but could not find one. Can someone help me find the document please. Otherwise does anyone have a step by step procedure of how to do it.
Overall Rating: 5 (1 ratings)
cg100668 Wed, 04/23/2008 - 04:27
Hello Sushil, Thanks for the information. However what I am looking for is a documentation where it explains the installation and configuration of the CUE as well as CCM 6.1 for both of them to interoperate.
The only information I found on is installation of Window based CCM 4.2 with CUE but not CCM 6.1 and CUE.
Brandon Buffin Wed, 04/23/2008 - 04:47
Take a look at the following document regarding the steps required for CCM.
The following documents will give you the steps for installing and configuring CUE.
Hope this helps. If so, please rate the post.
JB S Wed, 05/05/2010 - 08:47
Hi Sushil,
Have you got a most recent CUC compatibility matrix in the same format? If yes, could you please post a copy of it or even the link where you are downloading it from, as it would help in future in downloading most recent release.
Thanks Jai
JB S Thu, 05/06/2010 - 01:41
I have already got access to what you sent, what I asked Sushil was in the "same format" i.e. consolidated excel spreadsheet which he had posted on the forum.
Thanks anyways mate,  Jai
