problem with software management import with RME4.1.1 CWLMS3.1
Apr 23rd, 2008
Below is the output from the software management jobs
Device Name : C10K-PRE4-PHIL
Software import result - Failed
Total number of devices scheduled for image import : 1
Number of devices succeeded : 0
Number of devices failed : 1
Total time taken for Job - 3 Minutes 19 Seconds
Status of Job - FAILED
Starting Job: ID - 1054
Job Started At : Wed Apr 23 19:22:40 SGT 2008
Job running on : pldtpocsvr
Import Mode : Parallel
Protocol Order for Image Transfer : TFTP,RCP,SCP,HTTP
Total number of device(s) to be processed : 1
Processing Device : C10K-PRE4-PHIL
Start Time : Wed Apr 23 19:23:50 SGT 2008
Device is locked for exclusive access.
The supported protocols for image transfer are: TFTP,RCP,SCP
Importing the image c10k4-p11-mz.122-33.SB.bin from the device bootflash into the Software Repository.
Image will be copied to rep_sw_8601011000045198351 using TFTP.
Successfully imported the image from device.
Total time to copy the image - 1 Minute 10 Seconds
Moving c10k4-p11-mz.122-33.SB.bin from C:\PROGRA~1\CSCOpx\tftpboot\rep_sw_8601011000045198351 to job directory.
Successfully moved to C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1054\c10k4-p11-mz.122-33.SB.bin
Image Import from Device Complete
Device is unlocked.
Failed to add c10k4-p11-mz.122-33.SB.bin.
Reason : Exception occurred while getting Image Attributes
Device Import Result : Failed
End Time:Wed Apr 23 19:25:23 SGT 2008
SWIM0036: Could not add this image to software repository.
Adding Image C:\PROGRA~1\CSCOpx\files\rme\jobs\swim\1054\c10k4-p11-mz.122-33.SB.bin to Software Library
What could be the problem?
jsivulka Tue, 04/29/2008 - 05:55
This may be RME 4.0.4 Software Repository Problems. It looks to me like there is a problem with the script it is using, or the folder to which it is trying to store the image hasn't been created.
