static pat or asymmetric routing, whatever u may call it?
Apr 23rd, 2008
i have an application/web server on my private subnet, to which clients from internet connect. i have 2 wan links , (1 E1 and 1 ADSL) terminating on my 2811.
now i want to nat/pat client landing on my real IPs to be natted/patted to my server and the returning traffic should take the path where it originated from ( E1 or DSL)
the configuration is:
ip cef (by default)
int fa0/0
****DSL LINK ****
ip add 11.0.0.1
ip nat outside
int serial 0/0/0:2
******E1 LINK *******
ip add 12.0.0.1
ip nat outside
int fa0/1
*****SERVER SUBNET******
ip add 10.0.0.1
ip nat inside source static tcp 10.0.0.2 8090 11.0.0.1 8090 route-map one extendable
ip nat inside source static tcp 10.0.0.2 8090 12.0.0.1 8090 route-map two extendable
route-map one
match ip add 1
set interface fa0/0
route-map two
match ip add 2
set inter serial 0/0/0:2
acccess-list 1 permit any any
access-list 2 permit any any
ip route 0.0.0.0 0.0.0.0 fa0/0
ip route 0.0.0.0 0.0.0.0 serial 0/0/0:2
is there something i am missing?
the result are quite random. is there someother way to do this?
help required!!
thanks
RAZA
srmumtaz01 Wed, 04/23/2008 - 04:25
ip cef (by default)
int fa0/0
****DSL LINK ****
ip add 11.0.0.1
ip nat outside
int serial 0/0/0:2
ip add 12.0.0.1
ip nat outside
int fa0/1
ip add 10.0.0.1
ip nat inside
route-map one
match ip add 1
set interface fa0/0
route-map two
match ip add 2
help required!!
thanks
RAZA
