CVP 4.0SR2 - OSDM 2.0.3 - error.badfetch
Apr 23rd, 2008
Developing a Speech POC using Cisco Unified CVP 4.0 SR2, Nuance OSDM, OSR3.0 and c2800nm-ipvoice_ivs-mz.124-6.XT.bin as Cisco IOS voice browser
I am getting an error - A VoiceXML error occurred of type "error.badfetch" while invoking an Yes/No OSDM. This is the only OSDM which I have in the speech application.
Enabled debug (debug voip ivr all, debug http client all & debug vxml all) in the G/W and tried debugging the VXML G/W logs. But couldn't understand why error.badfetch occurs?
I am posting the logs captured from the G/W. Please help me to understand why the error.badfetch occurs and also help me to resolve the issue.
Thanks in advance
rbua Wed, 04/23/2008 - 06:31
Hi Sethu,
OSDM is provided as it is as a library and request a DEV Contract with Cisco AS for support on any customisation.
As a general reference badfetch is usually caused by the file not being available or loaded at the request time because of it size or miscaching.
Sethuramalingam... Wed, 04/23/2008 - 06:53
Thanks for the quick response.
We do have a Developer contract with Cisco. I have two questions:
1) What is the minimum & maximum file size supported for loading?
2) How do we know there is a miscaching and how it can be avoided?
rbua Wed, 04/23/2008 - 07:03
Hi Sethu,
please raise a request that way on the alias since it is free once you have the contract and there are people to assist.
There is not a minimum, this are the recommended settings:
ivr prompt memory 15000
http client cache memory pool 15000
http client cache memory file 600
I would recommend to hold prompt size as small as possible and eventually concatenate them to improve response, a basic measurement would be to avoid prompts larger then 1 MB.
You could check on cache occupancy by looking at it this way:
sh http client cache brief
Hope this helps.
PS Please rate useful posts accordingly
Sethuramalingam... Wed, 04/23/2008 - 23:21
I do have the same recommended cache configurations and prompt memory settings. But still getting the same error.
