Disable Express Setup on 2960
Answered Question
Hi All,
I inadvertently posted in WAN column. Is there a way to prevent erasing switch settings by holing in the MODE button? I would rather not give ability to an unsuspecting technician to nuke all my settings by holding in this button for 7 seconds.
thnx!
Correct Answer by andrew.butterworth about 9 years 4 weeks ago
In global config add the line:
no setup express
This doesn't prevent wiping the config through recovery though - i.e. holding the mode button whilst power cycling the switch and then going through the recovery procedure.
Andy
Overall Rating: 5 (1 ratings)
Correct Answer
andrew.butterworth Wed, 04/23/2008 - 05:28
  • Gold, 750 points or more
no setup express
Andy
