CUOM ExceededMaximumUptime on DevType: Voice GW
Apr 23rd, 2008
Operation Manager keep reporting for one of my H.323 GW's, that it has ExceededMaximumUptime on IF-X.X.X.X 10/75 [Vi1]
I cant see what is eventually wrong, and are not able to dig in any further on this. It is not possible to disable polling on this int. Are not sure what interface is causing this, the other GW is ok, and they have same conf.
irisrios Tue, 04/29/2008 - 06:04
  • Silver, 250 points or more
The ExceededMaximumUptime event or notification is generated if a backup interface stays up too long. The default is 0 seconds.
When you set the value of Maximum Uptime parameter on Backup or dial on demand Interface to 0, the ExceededMaximumUptime event gets disabled.
