Monitor Calls
Apr 23rd, 2008
What is the cheapest and easiest way to listen in on a phone call from another phone? We have a telerecruitment facility and the supervisors would like the ability to listen in on calls being made for training purposes.
Overall Rating: 5 (1 ratings)
MikeTomasko Wed, 04/23/2008 - 05:31
Can you point me in the direction of where I can find the documentation on how to do this with CRS? Thanks!
Brandon Buffin Wed, 04/23/2008 - 05:56
You will need a version of CRS that supports monitoring. For example, UCCE/IPCC Express Standard versions do not support monitoring. Beyond that, you will need to install this feature on your CRS server as indicated in the following document:
You will also need to configure your network to support monitoring. See the following document:
Hope this helps.
