Cisco 2950 swich blinking in red and green
Apr 23rd, 2008
I have one 2950 switch connected to router fastethernet.
But the problem the port in switch which is connected to router is continously blinking in green then red .
In switch console there is no message showing interface up down . pls help regaring this.
fherlan Wed, 04/23/2008 - 09:17
I sometimes had that issue when the connected device and the switch port could negotiate speed/duplex propperly.
Do you get messages like "duplex mismatch"?
Then you could lock both ports to e.g. 100FDX.
Hope it helps.
Yudong Wu Wed, 04/23/2008 - 10:36
Did you see any message regarding to duplex mismatch?
Is it blinking in green then red or green then amber?
Here is the info in installation Guide.
Alternating green-amber:
Link fault. Error frames can affect connectivity, and errors such as excessive collisions, CRC errors, and alignment and jabber errors are monitored for a link-fault indication.
