Cannot test translation rules
Answered Question
Apr 23rd, 2008
Hi All
I'm having trouble with a translation rules.
I created the following rules :
voice translation-rule 1
rule 1 /^8/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 1113
rule 1 /^8/ //
voice translation-rule 2222
rule 1 /91900......./ //
rule 2 /91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_8_OUTGOING
translate called 1113
but when i try to test them by using :
test translation rule 1 01604123456
it reports "translation rule 1 not defined" and the same on all the rules.
Any ideas?
Anthony
Correct Answer by Kenneth Mohammed about 8 years 9 months ago
Try "test voice translation-rule 1"
Hope that helps..if so please rate.
Overall Rating: 5 (1 ratings)
mciarfello Wed, 04/23/2008 - 12:27
Just a follow-up for completeness.
There were (still are) "translation rules" but are being replaced with the more robust voice translation-rules.
The new voice translation rules use use the pattern matching capabilities from Unix SED utility.
Now, does anyone want to map out the history of RTP priority, FRF.11, LLQ, etc QoS mechanisms? (semi-serious.)
