Agent Desktop Status
lkinchen
Can someone tell me why a supervisor see agents in not ready when they are in ready mode? Also, Agents are not receiving calls when they are in ready state.
check your refreash cycle on supervisor. Agents will receive calls based on your criteria so check your scripts or best way to do if you don't have access log one agent and send a call, also keep in mind if you don't have many calls and it seems agents are not getting calls.
Thanks for your response. I hate to sound stupid but how do I check the refresh cycle.
You go to View, and Preferences
Click on whatever item you want to change the refresh rate, then set it.
