Port 10000 or UDP 500 on firewall.
Apr 23rd, 2008
Do I have to open port on firewall in order to use vpn client3.x or 4.x to connect to outside network. How do I configure my ASA to allow port TCP 10000 or udp 500 opened.
Clarification: my user inside network unable to connect to outside network using vpn client.
JORGE RODRIGUEZ Wed, 04/23/2008 - 19:17
  • Green, 3000 points or more
Kehinde,
To use cisco vpn client from inside to connect to an outside RA Ipsec VPN server you simply need Ipsec pass through inspection configured in your global policy.
ciscoasa(config)# policy-map global_policy
ciscoasa(config-pmap)#class inspection_default
ciscoasa(config-pmap-c)#inspect ipsec-pass-thru
ciscoasa(config-pmap-c)#exit
See Ipsec pass through inspection section
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/inspect.html
you may also want to enable nat-t
ciscoasa(config)#crypto isakmp nat-traversal 20
Nat-T backround
http://www.cisco.com/en/US/docs/security/asa/asa81/command/ref/c5.html#wp2195488
Once done your inside cisco vpn clients should be able to vpn outside.
Rgds
Jorge
