ACD user in "Reserved" state
Apr 23rd, 2008
We have CRS 5.0 express premium and about 10 ACD agents. 1 of the agent
constantly gets stuck in "Reserved" state and unless their phone is reset the agent will
not go back to "ready' state. this starts hapenning at random times mostly. This has never happenned to any other agent.
Any help regarding this will be greatly appreciated!!
dehebert Wed, 04/23/2008 - 20:31
Have you turned tracing up for the agent desktop? What is differant about this agent than the other ones?
Naveen Raj Janardhan Thu, 04/24/2008 - 05:00
yes, the MIVR tracing has been turned on. This agent is set up just like all the other agents (in terms of calling search space, partition).
Naveen Raj Janardhan Fri, 04/25/2008 - 09:19
I have checked the firmware version to be SCCP41.8-3-3SR2S and the tftp setting seem to be correctly setup. However when I contacted my vendor he said that this could be a PC issue. I don't see any relevence to that. any other ideas?
