Cisco IOS NAT with Emule and Bittorrent
Apr 23rd, 2008
I have a Cisco 2621 running IOS version
c2600-ik9o3s3-mz.123-24a.bin
The setup is a very simple one. I have
a Windows XP sitting behind the Cisco 2621.
On the Windows XP, I run Emule and Bit
Torrent on the WinXP box. After about
an hour, the Cisco 2621 freezed up and
became un-responsive. The only solution
is to manually turn OFF/ON the power
button on the 2621 router.
Here is my configuration on the router:
interface F0/0
ip address 4.2.2.2 255.255.255.248
speed 100
dup full
ip nat outside
interface F0/1
speed 100
duplex full
ip nat inside
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 100 interface F0/0 overload
I have a 30Mbps download and 5Mbps upload. When the router is running
the # of NAT translation is about 200 and
the throughput is about 5Mbps download and 2Mbps upload.
What could be the issue that makes the router locked up after an hour. If I
stop emule and bit torrent, the router
can stay up and running for days without
issues.
Last but not least, if I replace the
Cisco 2621 with a Checkpoint NGx R65
Secureplatform firewall, I have no such issue.
When the rourer is up and running with
emule and bit torrent prior to locking up, cpu is about 40% and memory is about
75% utilization.
Any ideas anyone? Thanks.
ebreniz Tue, 04/29/2008 - 08:49
You can create an ACL on the router to block P2P ports such as 6881 (Bittorrent). Following link may help you
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6947/ps5207/ps6242/prod_white_paper0900aecd802efa46.html
You can use NBAR within IOS to block bittorrent. Here's an example of how to do it:
http://slaptijack.com/networking/controlling-peer-to-peer-p2p-traffic-with-cisco-nbar/
cisco24x7 Tue, 04/29/2008 - 08:54
I do NOT want to block Bittorrent or Emule. I
want to allow Bittorrent. I just do not want
Bittorrent or Emule to freeze up the router.
I do not have this issue with Checkpoint
firewall NGx R65. With IOS router, the router
locks up.
Any ideas on how to fix this?
