04-23-2008 07:27 AM - edited 03-15-2019 10:15 AM
I have a CUCM6BE implementation that uses 2800 routers as Voice Gateways to the PSTN.
The customer has an overhead paging system that consists of a analog 600ohm input to an amplifier which then connects to speakers. The previous PBX had a physical paging port which connected to the amp input.
I need to implement the paging system to the 2800 VGW.
I have found a document that describes the use of E&M for overhead paging. Is it possible to connect the 600ohm analog input directly to pins 4&5 of the E&M port, and then to call this port to access paging?
(Note: There is a PAM10 buffer/filter in front of the amp's input)
Does anyone know if this is possible, using FXS (ideal) or E&M VWICS? Any help would be much appreciated.
Richard
Solved! Go to Solution.
04-23-2008 07:54 AM
Somebody post a solution in this forum several years ago. Use a cheap IP phone and configure auto-answer to headset or speaker. Find the audio cable of headset or speaker. Connect the audio cable to your amplifier. That is it.
Hope this helps.
04-23-2008 07:49 AM
Hi Richard,
FXS or E&M should work nicely in this setup. Here is a good doc I received from Paolo;
Using Analogue E&M Ports to Interface to Overhead Paging Systems
http://cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008015094e.shtml
Or something like this with an FXS Port would also work well;
http://www.camelectronics.com/botateacmo.html
Hope this helps!
Rob
04-23-2008 07:55 AM
Hi Rob,
Thanks for the quick response and info.
The document describes the paging system having a switching pair (ie. push to talk). In my case the paging system is simply an analogue output.
I have tried connecting this to an FXS port and the port immediately goes off hook and it is not possible to call it.
I was hoping that by connecting it directly to port 4&5 the port could be set to auto answer and connect the speech path.
Do you know if this is possible?
Richard
04-23-2008 07:54 AM
Hope this helps.
04-23-2008 08:32 AM
Hi Richard,
Lets forget about the E&M for a moment :) If you look at the "Loop Start" section of this doc;
http://lib.store.yahoo.net/lib/cam-electronics/TAMBm.pdf
You will see that the TAMB answers the call via FXS on T&R and then bridges the audio across to the Paging Amp on dedicated pairs. You will need this mid-point device. I have worked with others who have successfully used this product.
Hope this helps!
Rob
04-25-2008 01:24 AM
Hi Rob and 4bwu,
Thanks very much for the advice.
As the customer already has some spare IP phones I am going to try the headset port option but if this is not suitable I will suggest that the customer purchases a TAMB unit.
Richard
04-25-2008 11:13 AM
You can also use this Valcom V-9940 and a Small Valcom power supply.
http://www.valcom.com/v-9940.htm
It will connect by FXS or FXO port and will give you a 600 or 8 ohm output.
It also supports loop supervision.
