Contact Center
We have many calls consider as abandoned due to caller hang-up, how I can make the calls consider abandoned if ring on agent more than 10sec, and if the calls ring on agent less than 10sec not consider as abandoned, because many calls hang-up after r...
matee by Level 1
  • 91 Views
  • 1 replies
Moving away from VXMLGW to VVB and I am curious about having multiple entries in the VVB host-to-ip configuration.   Today I have something like thismediaserver Datacenter1_ip1, Datacenter1_ip2mediaserver-backup Datacenter 2_ip1, Datacenter2_ip2 The ...
Hello folks, As you are aware Cisco officially stated that Device Targets are depreciated as of UCCE 9.0 and have recommended the use of Agent Targeting Rules as opposed to the legacy Device Target method.  I was wondering if there is any situation w...
saship by Level 1
  • 2276 Views
  • 8 replies
We got the license from licensing team but we found the issue about the license. Calabrio Workforce as attached screenshot. There is no license button to upload the license file. I’ve just checked with manual, it should be have. Does it need any fold...
nwannura by Level 1
  • 234 Views
  • 6 replies
Hello all, I want to ask, can we change the time of reservation at UCCX? If so, how can we do that? Currently on our production server, when the agent calls and they try to make the answer the call has dropped and then the call will be put into dispo...
Mustain by Level 1
  • 3105 Views
  • 11 replies
