cisco mst and third party rstp
Apr 23rd, 2008
hi,
we need to interconnect our lan ( switchs cisco 2950 3750 configuring with one mst region ( 2 instances)with a dslam allied telesis imap_9100. On it ,by default stp is disable and the mode is rstp ;
So my question is:
If i activate rstp on the imap what would be the result ??
thankx in advance
umedryk Tue, 04/29/2008 - 10:58
  • Bronze, 100 points or more
The only issue that has to be taken care is the configuration that needs to have 2 instances, instance 0 empty and instance 1 has all other vlans.
fd_case17 Tue, 04/29/2008 - 11:16
thancks,
I read that mstp is backward compatible with mst
Imap will listen for ist BPDU.
