RME 4.0.6, problem with authorization
Apr 23rd, 2008
after installing LMS 2.6, the rme-homepage shows the following error:
"You are not authorized to view the details" (see attachment). I recovered the password with "dbpasswd.pl", but without solution.
I do not why. Please help me.
Kind regards.
Volker
Volker Janusch Tue, 04/29/2008 - 22:32
No, this server is not integrated with ACS. The local user "admin" has all credentials.
Joe Clarke Wed, 05/28/2008 - 09:34
Please post the Tomcat stdout.log under NMSROOT/MDC/tomcat/logs.
Joe Clarke Fri, 01/02/2009 - 10:08
I missed this attachment. Your problem is being caused by either a bad regdaemon.xml, or a bad role map file. If you are still seeing this problem, I will need to see your NMSROOT/MDC/etc/regdaemon.xml file.
stephen.baugh Sat, 01/03/2009 - 22:43
Im seeing the following error message in the the Tomcat logs
DEBUG:appID for context:/rme from CCR:rme
[Sun Jan 04 06:33:16 GMT 2009] Authorization failed for user admin due to some internal error. Error = Unable to process CMF role file for application: rme
Unable to authorize user: admin
[Sun Jan 04 06:33:16 GMT 2009] The User admin is not allowed[Ljava.lang.String;@9e8310
[Sun Jan 04 06:33:16 GMT 2009] UII Tasks found! Lookup for CAM Tasks and then call CAM APIS!
[Sun Jan 04 06:33:16 GMT 2009] Task name RME_JOBS_DC_JOBS found in the UII Tasks XML file. Fetching the privileges!
