pix to check point vpn help
Apr 23rd, 2008
All, I need some help. Im trying to do a site to site vpn from my pix 515 with version 7.2 code on it to a check point firewall version R54. Can you guys check my config on the Pix side to make sure it looks ok? Im getting traffic one way only, and not the other way. In other words, from Pix site, I can ping a device at the check point site, but from the check point site, I can not ping anything from the pix side. A little help would be appreciated.
Overall Rating: 4 (1 ratings)
jjoseph01 Thu, 05/01/2008 - 21:29
Thanks. re-created check point side and it works. thanks for the link.
