Unity 4.0 VM Forwarding
Answered Question
Apr 23rd, 2008
Hi is it possible to have a Unity 4.0 system, forward VM to multiple subscribers, when a message is left on a group phone?
Correct Answer by Jaime Valencia about 8 years 11 months ago
if the message is left in a call handler set the message recipient as a PDL
javalenc
if this helps, please rate
Overall Rating: 3.8 (3 ratings)
Tommer Catlin Wed, 04/23/2008 - 10:47
  • Green, 3000 points or more
I do not think you can forward in that matter. Your options are:
- If using Unified Messaging with Exchange, setup a mail-enabled Public Folder. Associate this alias with the group mailbox number. When the voicemail is left, it will be deposited into the public mail folder you specified.
- Possibly use a server based rule wizard for any voicemail messages, forward to x, y and z.
hope this helps, maybe there are other solutions?
Correct Answer
Jaime Valencia Wed, 04/23/2008 - 12:29
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
