fast recovery from T1 failure in a dual T1 lease-line setup
Apr 23rd, 2008
We're looking for the best technology solution to most quickly recover from a single T1 outage, in a dual T1 lease-line setup.
Time sensistive application means we are looking for minimum recovery time from a failure.
spremkumar Fri, 04/25/2008 - 03:12
Is it a point to point setup between these two locations ?
if its the case have you configured dual static routes via the leased lines pointing towards the interface on which its terminated ?
Also do throw some light on the current setup you have in place out there.
regds
