Problem Installing Fabric Manager 3.2.3 on W2K3
Apr 23rd, 2008
Hello. I am trying to install Fabric Manager 3.2.3 on W2K3 and after starting the GUI, it is stopped with no error messages. It is working OK on Windows XP.
I have attached a shockwave to show you what I did
Any help ??
Gary Ross Wed, 04/23/2008 - 12:46
When you did the command line, is the m9000-fm-3.2.3.jar file in the specified location?
fmonettehp Wed, 04/23/2008 - 12:54
Since I took it (cut/paste) from the Install gui, I am expecting that the GUI gave me the right installation path. Am I right ???
Gary Ross Wed, 04/23/2008 - 13:22
I would get the location to see if the JAR file is there.
Also, I ran into this problem with an IBM install where the path to the install files was either to long and had spaces in it. If you have the CD, I would install it from there since your current path is very long and has spaces in it.
The IBM software I was trying to install was TPC that relies heavily on Java.
fmonettehp Thu, 04/24/2008 - 04:23
let me try it from a shorter path and let you know the result
thanks
Trending Topics: Storage Networking
