CM 6.1 upgrade
I have a upgrdaer upgrade. I have combined the iso images and when I put the disk into the pub it cannot find it.
Anyone upgraded to 61.3 without issues?
I have read the docs inside and out and I dont think I am doing anything wrong so unless it is a bad image (checksum) was fine ???????
gogasca Wed, 04/23/2008 - 20:00
Please try SFTP option
I have just downloaded the 2 files from CCO and merge them using COPY /B
C:\Documents and Settings\gogasca\My Documents\My Downloads\CCM SR and ES>COPY /B UCSInstall_UCOS_6.1.1.3000-2.sgn.iso_part1of2+UCSInstall_UCOS_6.1.1.3000-2.sgn.iso_part2of2 UCSInstall_UCOS_6.1.1.3000-2.sgn.iso
I used SFTP option for .sgn.iso file and that worked like a charm
I used as SFTP FreeFTPd
Dont rename the files please
I attached an screenshot
Let me know if that helps
