Cisco PIX Device Manager Version 3.0(2)
Apr 23rd, 2008
I have a PIX 515E:
Cisco PIX Firewall Version 6.3(4)
Compiled on Fri 02-Jul-04 00:07 by morlee
CCP-Firewall001 up 2 years 65 days
Hardware: PIX-515E, 32 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
0: ethernet0: address is 0012.80be.450d, irq 10
1: ethernet1: address is 0012.80be.450e, irq 11
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 3
Maximum Interfaces: 5
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
<--- More ---> Throughput: Unlimited
IKE peers: Unlimited
This PIX has a Restricted (R) license.
Serial Number: 808480455 (0x30306ec7)
Running Activation Key: 0xac646fed 0xf8b86795 0xc3951ec2 0xb32aed09
It's operate with Java plug in 1.4.1 y I have a PC with IE 7 and Plug in 1.6.0 y doesn't download the PDM.
Are there a solution for it?
Anonymous (not verified) Tue, 04/29/2008 - 11:09
Try Disable Java on Internet Options. This issue oculd be releated to Java version also.
