VPN client and radius or CAR
Hello:
I am trying to setup remote access vpn on IOS router with cisco Radius or CAR.
the vpn client user needs to be authenticated by group id and password, and user id and password.
How should I setup CAR, could someone provides me an example?
I saw this sample, but there is no relationship between user and group.
Any suggestions?
thx
[ //localhost/RADIUS/UserLists/Default/joe-coke ]
Name = joe-coke
Description =
Password = <encrypted>
AllowNullPassword = FALSE
Enabled = TRUE
Group~ =
BaseProfile~ =
AuthenticationScript~ =
AuthorizationScript~ =
UserDefined1 =
[ //localhost/RADIUS/UserLists/Default/group1 ]
Name = group1
Description =
Password = <encrypted> (would be "cisco")
Enabled = TRUE
Group~ =
BaseProfile~ = group1profile
UserDefined1 =
Define the group attributes such as pre-shared key, IP address pool name, etc. using Cisco
AV-pairs:
[ //localhost/RADIUS/Profiles/group1profile/Attributes ]
cisco-avpair = ipsec:key-exchange=ike
cisco-avpair = ipsec:tunnel-password=cisco123
cisco-avpair = ipsec:addr-pool=pool1
Service-Type = Outbound
jawicks Thu, 04/24/2008 - 03:50
  • Cisco Employee,
you can define the group locally on the router to define the values which the client will use to build the tunnel (pre-shared key, etc). The client's username/pw can then be defined within AAA server to allow access to the network once the tunnel has been established.
The link below should show how to setup the group config in IOS and you should change the AAA method to point to radius instead of local to authenticate the client at your AAA server.
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2308/products_configuration_example09186a00801c4246.shtml
