%SYS-2-MALLOCFAIL -- 3825 crash when ephones unregister register
Apr 23rd, 2008
Before the crash we see a lot of ephones unregistering / registering and soon the router crashes. Has happend twice in 5 weeks.
Same events occur in log before the crash.
Not sure if unregistering / registering of ephones causes the MALLOCFAIL crash of 3835 router.
Version:
flash:c3825-spservicesk9-mz.124-15.T4.bin
Apr 23 06:09:51.428: %IPPHONE-6-REG_ALARM: Name=SEP00131A6C25F2 Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:09:51.524: %IPPHONE-6-REGISTER_NEW: ephone-2:SEP00131A6C25F2 IP:10.120.86.25 Socket:1 DeviceType:Phone has registered.
Apr 23 06:09:53.996: %IPPHONE-6-REG_ALARM: Name=SEP00131A6C2E2E Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:09:54.100: %IPPHONE-6-REGISTER_NEW: ephone-3:SEP00131A6C2E2E IP:10.120.86.112 Socket:18 DeviceType:Phone has registered.
Apr 23 06:09:58.388: %IPPHONE-6-REG_ALARM: Name=SEP00131ADC5224 Load=CP7902080002SCCP060817A Last=TCP-timeout
Apr 23 06:09:58.492: %IPPHONE-6-REGISTER_NEW: ephone-4:SEP00131ADC5224 IP:10.120.86.103 Socket:34 DeviceType:Phone has registered.
Apr 23 06:11:22.740: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-2:SEP00131A6C25F2 IP:10.120.86.25 Socket:1 DeviceType:Phone has unregistered abnormally.
Apr 23 06:11:26.744: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-3:SEP00131A6C2E2E IP:10.120.86.112 Socket:18 DeviceType:Phone has unregistered abnormally.
Apr 23 06:11:59.679: %SEC-6-IPACCESSLOGNP: list 2 denied 0 127.127.7.1 -> 0.0.0.0, 4 packets
Apr 23 06:12:05.011: %IPPHONE-6-UNREGISTER_NORMAL: ephone-4:SEP00131ADC5224 IP:10.120.86.103 Socket:34 DeviceType:Phone has unregistered normally.
Apr 23 06:17:59.674: %SEC-6-IPACCESSLOGNP: list 2 denied 0 127.127.7.1 -> 0.0.0.0, 6 packets
Apr 23 06:18:40.997: %IPPHONE-6-REG_ALARM: Name=SEP00131A6C2599 Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:18:41.093: %IPPHONE-6-REGISTER_NEW: ephone-5:SEP00131A6C2599 IP:10.120.86.3 Socket:16 DeviceType:Phone has registered.
Apr 23 06:18:41.705: %IPPHONE-6-REG_ALARM: Name=SEP00131A592ABA Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:18:41.713: %IPPHONE-6-REG_ALARM: Name=SEP00131A6C2E2E Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:18:41.733: %IPPHONE-6-REG_ALARM: Name=SEP00131A6C2A92 Load=CP7912080002SCCP060817A Last=TCP-timeout
Apr 23 06:18:41.801: %IPPHONE-6-REGISTER_NEW: ephone-6:SEP00131A592ABA IP:10.120.86.123 Socket:18 DeviceType:Phone has registered.
Apr 23 06:18:41.809: %IPPHONE-6-REGISTER_NEW: ephone-3:SEP00131A6C2E2E IP:10.120.86.112 Socket:19 DeviceType:Phone has registered.
Apr 23 06:18:41.829: %IPPHONE-6-REGISTER_NEW: ephone-7:SEP00131A6C2A92 IP:10.120.86.119 Socket:20 DeviceType:Phone has registered.
Apr 23 06:18:42.685: %IPPHONE-6-REG_ALARM: Name=SEP00131ADC5224 Load=CP7902080002SCCP060817A Last=CM-aborted-TCP
Apr 23 06:18:42.785: %IPPHONE-6-REGISTER_NEW: ephone-4:SEP00131ADC5224 IP:10.120.86.103 Socket:34 DeviceType:Phone has registered.
Apr 23 06:19:03.129: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x60102BA0, alignment 0
Pool: Processor Free: 95296 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "Skinny MOH Server", ipl= 0, pid= 258, -Traceback= 0x61581D40 0x600F0A98 0x600F68D4 0x600F6E40 0x60102BA8 0x60103AF4 0x60191008 0x60182C0C 0x60183DFC 0x6017E618 0x61AAA100 0x605DAA9C 0x605E0594 -Traceback= 0x609EDFA8 0x60987FA8 -Traceback= 0x609EDAE8 0x609EDFDC 0x60987FA8
Apr 23 06:19:12.789: %ISDN-2-ISDN_FATAL: ISDN FATAL ERROR: file ../isdn/lif_common.c, function LIF_GetPkt, message: malloc of Buffer failed
Apr 23 06:19:12.789: %ISDN-2-ISDN_EXIT: malloc of Buffer failed
%Software-forced reload
18:19:12 NZST Wed Apr 23 2008: Breakpoint exception, CPU signal 23, PC = 0x60D8759C
Overall Rating: 4 (1 ratings)
Sushil Kumar Katre Wed, 04/23/2008 - 23:03
  • Gold, 750 points or more
This seems to be happening because of the MoH feature.
Are you using Flash of the router as MOH server?
You are running 12.4(15)T4 which is affected bu a BUG - CSCsk66907 -
%SYS-3-CPUHOG: due to Skinny MOH Server process
Alternate Headline: %SYS-3-CPUHOG: due to Skinny MOH Server process
Symptom:
CPU Hog due to Skinny MOH Server causing phones to unregister:
%SYS-3-CPUHOG: Task is running for (xxx)msecs, more than (xxx)msecs
(xxxxxx),process = Skinny MOH Server.
Conditions
Occurs if Music on Hold (MOH) is being streamed from flash in IOS 12.4(11)XW3
Workaround:
- Use the live feed option by plugging in a CD player or iPOD or any such
device to the MOH port on the UC500
- Disable MOH from flash - that implies tone on hold (or beep on hold)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk66907
Try disabling MOH server on flash and keep it under observation for some time to see if this resolves the issue. In the mean while have a separate MOH server.
This issue is resolved in the followig releases -
12.4(17.9)PI1c
12.4(11)XW5
12.4(15)XY
So you can look for upgrading the router as well.
I'll appreciate if you can send us the show tech output from the router.
-> Sushil
astanislaus Wed, 04/23/2008 - 23:38
Sushil,
Thanks for the information. The customer just said to me that the fault may be related to a faulty PoE switch that is intermittently loosing power and turning OFF / ON and hence a whole heap of phones to deregister / register. We think that may be the reason for MALLOCFAIL because a lot of ephones are deregistering/registering at the same time.
