gojericho0 Thu, 04/24/2008 - 05:15
Yes, but it will have to be an extended ACL
Lets say your VLAN range is you can create a ACL targeted for a different network
Router(config)# access-list 101 allow ip any
This would allow any traffic from
You could then place this access list on the SVI of your VLAN
Router(config-if)#ip access-group 101 in
acomiskey Thu, 04/24/2008 - 06:24
The only source addresses from that vlan would be when the acl is applied in.
int vlan 10
ip addr
If it were applied "out", then the source could be any.
