HWIC-1FE
Answered Question
Apr 23rd, 2008
I have installed HWIC-1FE card on Cisco 2811 router but in show diag it shows "Unknown WAN daughter card
WIC module not supported/disabled in this slot ".
IOS Version which I am using is 12.4(17)bin with advance IP services K9 feature set.
can somebody help?
regds
aman
Correct Answer by paolo bevilacqua about 9 years 3 months ago
Yes or latest T.
Overall Rating: 3 (1 ratings)
paolo bevilacqua Wed, 04/23/2008 - 23:56
  • Hall of Fame,
    Founding Member
You need 12.4(11)XJ4 or newer for that card.
amansoi_5 Thu, 04/24/2008 - 00:46
But I have 12.4(17) working on router.
Is it like that I need 12.4(11)XJ only.?
aman
Correct Answer
paolo bevilacqua Thu, 04/24/2008 - 02:18
  • Hall of Fame,
    Founding Member
Yes or latest T.
amansoi_5 Tue, 04/29/2008 - 20:26
I loaded 12.4(11)XJ image & card is working .
thanks.
aman
jay77jay77 Tue, 04/29/2008 - 22:28
hi
what is the difference between T release or XJ image and images without either T or XJ etc
Tks
