Terminal Services with VPN
Apr 23rd, 2008
I will hava a terminal server somewhere in the internet. Now thin clients should work on the terminal server.
To have a secure connection I will user a VPN. There should be a site-to-site and also a remote access VPN.
And I have more then 50 clients, which work on the server.
What would be a good solution for this problem. IPsec or SSL and which devices should I use? VPN Concentrator, PIX Firewall or a router?
Is also OpenVPN a good solution?
Thanks for your help.
