Failover using NAT
t814687 Thu, 04/24/2008 - 07:38
What network you want to fail-over? Please elaborate exactly what you trying to achieve.
In the diagram, router3 is my remote router, connected to core router1 and router2. All routers are running EIGRP. I want to know if router1 or router2 links fails/bounces, how can i use/incorporate NAT as a failover between the 2 core routers? I don't exactly know if this is possible or not.
Thanks.
t814687 Fri, 04/25/2008 - 07:10
Generally speaking NAT is not a failover mechanism. You should use your EIGRP and advertize default route out of router 2 should router 1 connection fails.
