no negotiate auto
Answered Question
Apr 24th, 2008
Cisco 7204VXR router has "no negotiate auto" config'd on gig interface.
interface GigabitEthernet0/2
ip address x.x.195.245 255.255.255.248
duplex auto
speed auto
media-type rj45
no negotiation auto
Will this cause slowness across interface because this is disabled? Would there be any interface errors associated with this as well?
I'm trying to determine why it seems to take a little longer when I telnet to this particular router....delay when asking for login.
Thanks in advance for info.
Correct Answer by mohammedmahmoud about 8 years 11 months ago
The auto-negotiation option is only effective when using the GBIC media, it is used to enable the IEEE 802.1z Gigabit Ethernet (1000 Mbps) auto-negotiation protocol, thus the auto-negotiation feature is not supported when using the rj-45 media type (which is your case) and will be ignored if enabled, more over this feature has no relation with slowness or delay over the interface.
BR,
Mohammed Mahmoud.
Overall Rating: 4 (1 ratings)
Correct Answer
mohammedmahmoud Thu, 04/24/2008 - 06:58
  • Green, 3000 points or more
BR,
Mohammed Mahmoud.
