VPN Clients Internet Browsing
Apr 24th, 2008
I have set up in a lab right now a ASA 5520 with a live internet connection. I have a 2611 haning off the inside interface, and a 2950 switch into which I have an AD server plugged in. I have VPN set up for Cisco VPN client. I can connect up just fine, get an address from the address pool and connect all over the lab. I can not, however get to the internet. If I try to ping or browse, it resolves the name to an address, but times out trying to get there. I can get to the internet from the lab PC's no problem. It's probably something simple I am missing, any help would be great. I am attaching the ASA config. Thanks!
Overall Rating: 5 (1 ratings)
acomiskey Thu, 04/24/2008 - 05:47
Since you have already defined nat for the vpn clients, I assume you don't want to split tunnel...
global (Internet) 1 72.X.X.X netmask
nat (Internet) 1
To complete the hairpin, you are missing...
same-security-traffic permit intra-interface
adcorbett_2 Thu, 04/24/2008 - 06:02
Yeah, we are trying to avoid split-tunneling. Thanks, I added that but it's still not working.
adcorbett_2 Thu, 04/24/2008 - 06:56
Ok, I will take a look at that thanks. In the meantime, I am attaching my router and switch configs, just incase I missed somethig there, and if I did..I will be embarassed :-)
Lab subnet -
VPN Pool -
adcorbett_2 Thu, 04/24/2008 - 07:41
Ok, I went through that document and still nothing, also I checked the client stats and do have 0 0 under secured routes.
adcorbett_2 Thu, 04/24/2008 - 11:31
Anyone else want to take a crack at this? I have rebuilt the whole ASA and here is the cleaned up config, but alas, still no interet for VPN users. When I ping a website, it resolves the name to an IP but times out.
acomiskey Thu, 04/24/2008 - 11:56
A few more things to try. Have you considered upgrading from 7.1.2?
Also, this route statement is not correct. Not that this will fix your internet problem however.
route Inside 1
Your vpn pool is part of and is not reachable via
This also shouldn't matter but try...
nat (Internet) 1
adcorbett_2 Fri, 04/25/2008 - 04:51
All set..after adding
No nat (Internet) 1
nat (Internet) 1
clear xlate
clear local
everything is working now. Thanks for the input!
