LMS 3.0 Install Error in Solaris 9
Apr 24th, 2008
Hi Everyone,
I'm trying to install the LMS 3.0 Evaluation Software in a Sparc with Solaris 9 but after answer all the installation questions i receive the following messages :
ERROR: The following base package image is bad: CSCOclsch.
ERROR: The following base package image is bad: CSCOcomon.
ERROR: The following base package image is bad: CSCOdal.
ERROR: The following base package image is bad: CSCOdm.
ERROR: The following base package image is bad: CSCOopmgr.
ERROR: The following base package image is bad: CSCOplr.
ERROR: The following base package image is bad: CSCOstl.
ERROR: The following base package image is bad: CSCOipmutl.
ERROR: The following base package image is bad: CSCOcli.
This happens to all packages...
I download the evaluation zip file from Cisco and create the DVD using mkisofs with Rock Bridge Extensions.
I'm trying to install directy from the DVD-ROM /cdrom/cdrom0 using a telnet session...
Any tip or help ?
Thanks in Advanced
Andre Lomonaco
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 04/24/2008 - 09:10
Either your download is bad, or the burn was bad. If you copied the directory structure, make sure you used a tar copy to preserve all attributes exactly. For example:
mkdir /dst/dvd
cd /src/eval
tar cpf . - | (cd /dst/dvd && tar xpf -)
Before creating your IOS, you can run disk1/checkPkgIntegrity.sh to validate the consistency of the packages.
lomonaco Thu, 04/24/2008 - 14:26
Hi Jclarke, thanks a lot for your prompt reply...
I take a look and appears there is an bug with solaris 9 and pkgchk. Please take a look in this thread
http://www.unixadmintalk.com/f5/solaris-9-pkgchk-34021/
When checkPkgIntegrity.sh is running, there are a lot of erros (modtime). So the install doesn't go on..
I'm trying to find a workaround.
Thanks in Advanced,
My Best Regards
Andre Lomonaco
Joe Clarke Thu, 04/24/2008 - 15:35
The package bits must have their mtime attributes match with the pkgmap exactly. Under normal circumstances, this is never a problem. We have not seen an issue where customers got these errors when installing on Solaris that could be attributed to a pkgchk bug. The problem was either a bad download/copy, or an issue with what we posted on Cisco.com.
Since I have not heard anyone else complain about a bad eval installation, please detail every step you took to download and create the DVD.
lomonaco Fri, 04/25/2008 - 10:31
Hi Jclarke, here my steps:
1) Download lms-s_3_0.zip from Cisco.
MD5 CheckSum 05572980d35f40ffc393bc28a3a4d2cc
2) Unzip lms-s_3_0.zip in Windows XP
The directory lms-s_3_ is created
3) I create the CD using the following command:
C:\temp>mkisofs -o ciscoworks.iso -d -l -L -r -R -J -V CiscoWorks C:\lomonaco\CiscoWorks\CD\lms-s_3_
I used Nero to burn the Iso image
4) I put in my Solaris Server in cdrom/cdrom0
5) The install process works fine until the checkPkgIntegrity.sh script
6) Here the errors when I execute pkgchk from console:
sa-corp-ciw1:/cdrom/cdrom0/packages# pkgchk -d . CSCOafd
Checking uninstalled directory format package from
packages>
## Checking control scripts.
## Checking package objects.
ERROR: /cdrom/ciscoworks/packages/CSCOafd/reloc/CSCOpx/MDC/tomcat/webapps/triven
i/RSRC/en_US/images/arrow_rt.gif
modtime <08/13/03 08:02:09 PM> expected <08/13/03 04:02:08 PM> actual
i/RSRC/en_US/images/btn_history32.gif
modtime <08/13/03 08:02:10 PM> expected <08/13/03 04:02:10 PM> actual
i/RSRC/en_US/images/corner_02.gif
modtime <06/19/02 07:31:27 PM> expected <06/19/02 03:31:26 PM> actual
7) All modtime errors is showing a difference of 4 hours. Can be something related with my timezone (Brazil/East) ???
8) Here my Solaris Version:
Solaris 9 9/04 s9s_u7wos_09 SPARC
Copyright 2004 Sun Microsystems, Inc. All Rights Reserved.
Use is subject to license terms.
Assembled 29 June 2004
Thanks in Advanced
Andre Lomonaco
Joe Clarke Fri, 04/25/2008 - 10:42
When you extract the zip file, what are the timestamps on those same files? It may be that your unzip program is modifying the timestamps based on your local time. You might also try downloading the zip file to Solaris, and using mkisofs on Solaris to build the image, then burn it on your PC.
lomonaco Mon, 04/28/2008 - 05:46
Hi jclarke,
What's the best way to extract the evaluation zip file download from cisco
(lms-s_3_0.zip) in Solaris 9 to keep the atributes and the correct pkgmap and pkginfo informations ?
Thanks in Advanced,
Andre Lomonaco
lomonaco Mon, 05/12/2008 - 09:03
Hi jclarke,
I couldn't create my image but at least I received the disk from cisco and all works as described in the installation guide.
Thanks for all
My Best Regards,
Andre Lomonaco
