Warning message
No Audio on outbound call
Apr 24th, 2008
Hi All
We have uc520 with two sip dial peers that connect to local sip gateway device.
Configuration :
dial-peer voice 202 voip
destination-pattern 8T
session protocol sipv2
session target ipv4:192.168.4.4
session transport udp
dtmf-relay rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 203 voip
destination-pattern 7T
dtmf-relay sip-notify
codec g711ulaw
no vad
Incoming calls work fine from sip device to UC520
dial-peer 203 works fine for outbound calls. But dial-peer 202 rings out but then loses audio when connection answered.
I thought it had to be a config problem on sip device BUT if i replace UC520 with my old 1760 CME - it works!
Both dial peers are configured same on sip device - so problem is in config on UC520 - but can't figure out where?
Any ideas on how to debug this issue?
Thanks in advance
anthonyfear Thu, 04/24/2008 - 17:37
Update:
Tried all sorts to rectify this but eventually did a "debug ccsip all" and could see that audio stream was failing when call was answered.
Finally figured out it was happening because gateway device was issuing reinvite and that was failing to get through to CME.
Still not sure how to fix this (I guess it`s probably a firewall / nat issue) but I configured gateway not to reinvite and outbound calls now work.
