IPIVR 4.5(2)- sending email from script
Apr 24th, 2008
Hello all! I have a script, that creates an email and sends immediately. It's working just fine, but I am unsure of how to add multiple email addresses for the same email. So, I want to send the same email to 3 individuals. Always the same email addresses, no database dips, or gathering info from caller. We are simply notifiying when this particular "option" was selected, so we can alert these 3 individuals. Is it possible to have more than one email address in the send email step, and if so.. HOW do I script that?
MANY THANKS!
ibodalija Thu, 07/10/2008 - 03:44
You've probably already figured it out but you can use semicolones in your string variable e.g. "[email protected]; [email protected]; [email protected]". It should work just fine.
i.
