VLAN Trunking + VPT
Answered Question
I have two 3750 switch connected to eatch other.
There's a 802.1Q trunk between the two switchs. There's also VTP and Spantree activated on those switch. The two switch are in the same VTP domain, and they are server.
I added a VLAN 185 on the first 3750, and it did not reply on the second.
So I added manually in the second 3750 the VLAN 185.
I've configured an interface VLAN185 in both switchs, in the same network.
EX :
SWITCH1 : Int vlan185 ip : 10.10.1.1 255.255.255.0
SWITCH2 :Int vlan185 ip : 10.10.1.2 255.255.255.0
MY PROBLEM :
I'm not able to ping on both side anything in the vlan 185.
Tanks a lot.
Shera
Correct Answer by Kevin Dorrell about 9 years 3 months ago
Mmm. That is strange because it looks like the MD5 digest is different on the two switches. Sorry to insist, but are you sure there is not a VTP password? I have a synchronised domain, and I have the same MD5 digest on both server switches.
I presume these two switches are directly connected together via 3750-2 G1/0/25 to 3750-1 don't-know which port. Perhaps it would be useful to see the configs of the two ports connecting them together and a show cdp neighbor G1/0/25 detail.
Kevin Dorrell
Luxembourg
Overall Rating: 4.5 (2 ratings)
mohammedmahmoud Thu, 04/24/2008 - 11:55
  • Green, 3000 points or more
Hi Shera,
First we need to make sure that the trunk between the switches is operational and thus please post a "show interfaces trunk", second we need to check the VTP status and thus please post a "show vtp status".
BR,
Mohammed Mahmoud.
Here's the first 3750
3750-1-10.10.10.110#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/21 on 802.1q trunking 1
Gi1/0/22 on 802.1q trunking 1
Gi1/0/23 on 802.1q trunking 1
Gi1/0/24 on 802.1q trunking 1
Gi1/0/25 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/0/21 1-4094
Gi1/0/22 1-4094
Gi1/0/23 1-4094
Gi1/0/24 1-4094
Gi1/0/25 1-4094
Port Vlans allowed and active in management domain
Gi1/0/21 1-2,8,10,16,161-162,167,185,192
Gi1/0/22 1-2,8,10,16,161-162,167,185,192
Gi1/0/23 1-2,8,10,16,161-162,167,185,192
Gi1/0/24 1-2,8,10,16,161-162,167,185,192
Gi1/0/25 1-2,8,10,16,161-162,167,185,192
Port Vlans in spanning tree forwarding state and not pruned
SSM-3750-001#sh vtp status
VTP Version : 2
Configuration Revision : 9
Maximum VLANs supported locally : 1005
Number of existing VLANs : 14
VTP Operating Mode : Server
VTP Domain Name : CHBE
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0xBB 0x9E 0x23 0x70 0x2C 0x32 0x6E 0x05
Configuration last modified by 10.10.10.140 at 4-15-08 13:53:41
Local updater ID is 10.10.10.140 on interface Vl1 (lowest numbered VLAN interface
3750-2-10.10.10.140#sh int trunk
Gi1/0/1 auto n-802.1q trunking 1
Gi1/0/17 auto n-802.1q trunking 1
Gi1/0/24 auto n-802.1q trunking 1
Gi1/0/26 on 802.1q trunking 1
Gi1/0/28 on 802.1q trunking 1
Gi1/0/1 1-4094
Gi1/0/17 1-4094
Gi1/0/24 1-4094
Gi1/0/25 1-4094
Gi1/0/26 1-4094
Gi1/0/28 1-4094
Gi1/0/1 1-2,8,10,16,161-162,167,185,192
Gi1/0/17 1-2,8,10,16,161-162,167,185,192
Gi1/0/26 1-2,8,10,16,161-162,167,185,192
Gi1/0/28 1-2,8,10,16,161-162,167,185,192
Gi1/0/24 1-2,8,10,16,192
PACS_3750-01#sh vtp status
VTP Version : 2
MD5 digest : 0x1C 0x34 0x71 0xAF 0xD5 0x1F 0xC4 0x8A
Configuration last modified by 10.10.10.110 at 4-15-08 12:46:46
Local updater ID is 10.10.10.110 on interface Vl1 (lowest numbered VLAN interface found)
Maybe this will help :
3750-2-10.10.10.140#sh spanning-tree root priority
VLAN0001 4097
VLAN0002 8194
VLAN0008 8200
VLAN0010 4106
VLAN0016 8208
VLAN0161 32768
VLAN0162 32768
VLAN0167 32768
VLAN0185 32768
VLAN0192 4288
#sh spanning-tree root port
VLAN0001 GigabitEthernet1/0/25
VLAN0002 This bridge is root
VLAN0008 This bridge is root
VLAN0010 This bridge is root
VLAN0016 This bridge is root
VLAN0161 GigabitEthernet1/0/25
VLAN0162 GigabitEthernet1/0/25
VLAN0167 GigabitEthernet1/0/25
VLAN0185 GigabitEthernet1/0/24
VLAN0192 This bridge is root
3750-1-10.10.10.110#sh spanning-tree root priority
VLAN0001 4097
VLAN0002 4098
VLAN0008 4104
VLAN0010 4106
VLAN0016 4112
VLAN0161 32768
VLAN0162 32768
VLAN0167 32768
VLAN0185 32768
VLAN0192 4288
VLAN0001 This bridge is root
VLAN0010 GigabitEthernet1/0/26
VLAN0185 GigabitEthernet1/0/25
VLAN0192 GigabitEthernet1/0/26
mohammedmahmoud Thu, 04/24/2008 - 13:45
Sorry for the delay, can you please post a "show vtp password", "sh ip int brief" and "show ip route".
BR,
Mohammed Mahmoud.
mohammedmahmoud Thu, 04/24/2008 - 15:02
Shera,
I've to go for now, to guide you in the logical directions, please check the VTP password on both switches, please make sure that the SVI interfaces are up/up and that ip routing is enabled.
BR,
Mohammed Mahmoud.
hi,
Here it goes with VTP counters
3750#sh vtp counters
VTP statistics:
Summary advertisements received : 1013
Subset advertisements received : 11
Request advertisements received : 0
Summary advertisements transmitted : 971
Subset advertisements transmitted : 11
Request advertisements transmitted : 2
Number of config revision errors : 0
Number of config digest errors : 0
Number of V1 summary errors : 0
the other switch
3750-01#sh vtp counters
VTP statistics:
Summary advertisements received : 986
Subset advertisements received : 12
Request advertisements received : 2
Summary advertisements transmitted : 1027
Subset advertisements transmitted : 14
Request advertisements transmitted : 1
My collegue made an error with the sh VTP counters.
So those are the good one.
110 -3750-01#sh vtp counter
VTP statistics:
Summary advertisements received : 232553
Request advertisements received : 88268
Summary advertisements transmitted : 407709
Subset advertisements transmitted : 88258
Request advertisements transmitted : 0
Number of config revision errors : 12906
VTP pruning statistics:
Trunk Join Transmitted Join Received Summary advts received from
non-pruning-capable device
Gi1/0/1 0 0 0
Gi1/0/17 0 0 0
Gi1/0/24 0 0 0
Gi1/0/25 0 0 0
Gi1/0/26 0 0 0
Gi1/0/28 0 0 0
140 -3750-001#sh vtp counters
VTP statistics:
Summary advertisements received : 703927
Request advertisements received : 352310
Summary advertisements transmitted : 1406744
Subset advertisements transmitted : 352321
Number of config revision errors : 176247
Gi1/0/21 0 0 0
Gi1/0/22 0 0 0
Gi1/0/23 0 0 0
Gi1/0/24 0 0 0
Gi1/0/25 0 0 0
Correct Answer
Kevin Dorrell Fri, 04/25/2008 - 07:23
Kevin Dorrell
Luxembourg
