Monitor network traffic via SNMP
Apr 24th, 2008
I am looking to gather network traffic using SNMP. The data I am really interested in is bits per second, the show interface summary command. I have figured out how to get ifIn/OutOctet using SNMP however I really want bits per second. Anyone have any ideas on what if I can use?
t814687 Thu, 04/24/2008 - 19:41
have you tried MRTG tool? I think it can show performance stats the way you want it.
carl.wertz Fri, 04/25/2008 - 04:09
OK. Is this tool part of a suite? I am on a system where I dont have much play with it. I am looking to use a snmpwalk against a MIB. Any information on that?
t814687 Fri, 04/25/2008 - 05:26
well, snmpwalk is not the best tool. for mrtg you need perl. google MRTG and you will see what it can do.
Otherwise look at this OUI:
locIfOutBitsSec
Provides a weighted 5-minute exponentially decaying average of interface output bits per second for the specific protocol.
Syntax: Integer
Access: Read-only
and this:
locIfInBitsSec
Provides a weighted 5-minute exponentially decaying average of interface input bits per second.
Syntax: Integer
Access: Read-only
