aaa ?
Apr 24th, 2008
I have the following aaa config:
aaa new-model
aaa authentication login default group radius line
radius-server host 172.16.1.254
radius-server key WinRadius
line con 0
line vty 0 4
password line
My radius config is working fine but by default the aaa config is being applied to the console, tty's etc.
Is there a way to configure using aaa but not to use the console. i.e. apply aaa to all methods of connecting to the router/switch bar the console port ?
PS: I've tried here :
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfathen.html
without success,
Phil.
philth_123_2 Thu, 04/24/2008 - 09:43
I've found it.
aaa authentication for-console local
Username local password local
line con 0
login authentication for-console
Phil.
Richard Burts Thu, 04/24/2008 - 09:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Phil
The simple answer to your question is that no there is not a way to have aaa apply to vty but not to console.
The more complex answer is that you can configure one aaa method to apply to vty (as you have done) and can configure another aaa method to apply to console.
If I can guess that you want the vty to authenticate with radius but want the console to just authenticate with its line password then you could try configuring this:
aaa authentication login consoleauth line
line con 0
login authentication consoleauth
This will allow the console to authenticate with its line password while the vty still authenticate with radius and use the line password as a backup if radius is not available.
Rick
