UCCX Aborted Contact Error
I am getting the following error for aborted contacts on a CRS 5.0.1 system.
Was wondering if anyone has seen this, or can point me to a list of exceptions that I can further investigate.
15115271: Apr 24 10:38:21.781 CDT %MIVR-SS_TEL-5-EVENT_NOT_RECEIVED:Event not received: All Call ids=CallID:20085 MediaId:156897/2 Task:17000042447,Missing Event=ACTIVE_EV,Exception=null
15115272: Apr 24 10:38:21.781 CDT %MIVR-SS_TEL-3-WAIT_FOR_CALL_AND_MEDIA_ACTIVE_FAILED:Waiting for call and media active failed: All Call ids=CallID:20085 MediaId:156897/2 Task:17000042447,Time Lapse=5000
15115273: Apr 24 10:38:21.781 CDT %MIVR-APP_MGR-3-TASK_ABORTED:Application task aborted: Application=App[name=RFS,type=Cisco Script Application,id=5,desc=RFS,enabled=true,max=25,valid=true,cfg=[ApplicationConfig[schema=ApplicationConfig,time=Fri Mar 07 13:09:22 CST 2008,recordId=27,desc=RFS,name=RFS,type=Cisco Script Application,id=5,enabled=true,sessions=25,script=SCRIPT[RegistrationAndFinancialServices.aef],defaultScript=SCRIPT[DefaultScript.aef],vars=[],defaultVars=[<java.lang.String DefaultExtension>]]]],Application Trigger=ContactApplicationTrigger[time=1209051496765,locale=en_US,cfg=JTAPITriggerConfig[schema=ApplicationTriggerConfig,time=Wed Mar 26 06:48:06 CDT 2008,recordId=26,desc=Cisco JTAPI Trigger,name=5613,type=Cisco JTAPI Trigger,appName=RFS,enabled=true,sessions=25,idleTimeout=5000,locale=en_US,parms={},taskGroups=[],controlClass=class com.cisco.call.CallControlChannel,controlGroupId=0,contactGroups=[GroupInfo[class=com.cisco.dialog.DialogChannel,id=0]],dn=5613,cmDeviceName=RFS,cmDeviceInvalid=false,cmDescription=Registration and Finacial Services,cmDevicePoolUUID={6D08CEED-BB4C-4F54-AE0E-63B1F2FBC3A9},cmDevicePoolName=COLUMBIA-COLLEGE-DP,cmCallingSearchSpaceUUID=,cmCallingSearchSpaceName=None,cmLocationUUID={29C5C1C4-8871-4D1E-8394-0B9181E8C54D},cmLocationName=Hub_None,cmPartitionUUID=,cmPartitionName=None,cmVoiceMailProfileUUID=,cmVoiceMailProfileName=None,cmCallPickUpGroupUUID=,cmCallPickUpGroupName=,cmDisplay=,cmExternalPhNumMask=,cmFwdBusyVM=false,cmFwdBusyDest=,cmFwdBusyCSSUUID=,cmFwdBusyCSSName=None,cmAlertingNameAscii=,cmPresenceGroupUUID=ad243d17-98b4-4118-8feb-5ff2e1b781ac,cmPresenceGroupName=Standard Presence group],contact=JTAPICallContact[id=20085,implId=156897/2,state=STATE_ATTRIBUTED_IDX,inbound=true,App name=RFS,task=17000042447,session=12000020391,seq num=0,cn=5613,dn=5613,cgn=4078352300,ani=null,dnis=null,clid=null,atype=DIRECT,lrd=null,ocn=5613,route=RP[num=5613],TP=5494]],Task id=17000042447,Task Class=class com.cisco.app.impl.WFWorkflowAppDebugTaskWrapper,Exception=com.cisco.channel.ChannelExecutionException: Contact id: 20085, Channel id: 136, Reason: UNCAUGHT_EXCEPTION, CallID:20085 MediaId:156897/2 Task:17000042447, answer failed to get ack events, timeout: 5000; nested exception is:
com.cisco.wfapi.WFExecutionException: CallID:20085 MediaId:156897/2 Task:17000042447, answer failed to get ack events, timeout: 5000
Overall Rating: 5 (1 ratings)
htarra Wed, 04/30/2008 - 09:11
  • Bronze, 100 points or more
This message is usually seen when Calling party Calling party's Codec could not connect at G711 to IVR. The Call Manager traces should show
why the connection failed.
