pppoe over adsl is slow
m-haddad Thu, 04/24/2008 - 12:40
Try to set the MTU to 1492.
Please let me know how it goes,
alaeldien Wed, 11/26/2008 - 02:48
iam having the same scenario, just you need to check the modem ,and before that ajust the MTU in by using Dr.TCP
Hope to help
usslindstrom Wed, 11/26/2008 - 01:17
I honestly don't mean to thread-jack... But were you ever able to find a solution to this problem?
I'm experiencing the exact same issue on an 1841 w/PPPoE to an ADSL Bridge.
I've tried everything I can think of at the moment, but no-go on all counts. If we compare configs or so, we might be able to come up with a viable solution.
dlongpre Mon, 12/15/2008 - 22:10
I have the same issue on 1811 (12.4(15)T7) w/PPPoE to an ADSL Bridge modem. From the Cisco router itself, even pinging the Dialer IP is "very" slow i.e 105 ms. I "pinged extended" the router IP loopback from IP source "inside" interface and it's okay (1 ms). I tried disabled CEF and Inspect on Dialer interface, just in case, and still the same problem when pinging the Dialer IP i.e 105ms. Any idea?
Here the interfaces config:
interface FastEthernet0
description OUTSIDE Zone (To Modem ADSL)
no ip address
ip mtu 1492
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
ST-LO#sh run int dialer0
interface Dialer0
description PPPoE (linked to Fa0)
mtu 1492
ip address negotiated
ip access-group acl-outside in
no ip unreachables
ip nat outside
ip inspect france-fw out
no ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp chap hostname xxxxxxxx
ppp chap password 0 xxxxxxx
usslindstrom Mon, 12/15/2008 - 23:56
Well, going over our 2 config's - they're almost 100% identical.
I've played with the MTU settings, and even gone as low as 800, but nothing seems to affect it.
Here is the config, and some output commands:
Here are the router specs:
Cisco 1841 (revision 7.0) with 354304K/38912K bytes of memory
Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
flash: c1841-adventerprisek9-mz.124-15.T3.bin
Running Config:
interface FastEthernet0/1
description USS_WAN
no ip address
speed 100
no cdp enable
interface Dialer1
ip mtu 1452
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname -----
ppp chap password -----
ppp pap sent-username ----- password -----
ppp ipcp route default
The solution that I've had to use as of current - is the have the original ISPs craptastic equipment in place, and drop the cisco router into a DMZ of their equipment.
Doing it that way allows me to get the speed up to par with what it should be, and also use most/all of the features that the Cisco router gives me (VPN, etc.)
Unfortunately - it's very sad that my very expensive Cisco Router and very expensive Cisco modules - can't do the basic things that a $20 over-the-counter router can do. (cough* train itself on vpi/vci etc. cough*)
And thus, a using a combination of the two (Cisco Router and ISPs) is pretty much mandatory at this point in the game.
