ACE's mac-sticky equivalent on CSS
Apr 24th, 2008
Been working only on ACE equipment and now I have to solve a mac sticky problem, but on a CSS instead.
mac-sticky is enabled on a vlan interface on an ACE in bridged mode, it make sure that all traffic sourced on that interface is destined back through the same interface.
My question is how would I solve this with CSS if you could paste a sample config It would be greatly appreciated!
//tyrone
Overall Rating: 4 (1 ratings)
Gilles Dufour Fri, 04/25/2008 - 00:51
  • Cisco Employee,
Not really an equivalent but the following command is often required on the CSS when configured in bridge mode.
CSS11503-2(config)# ip uncond-bridging
This tells the CSS to first bridge and only route if needed.
Gilles.
770801tvdhaar Tue, 04/29/2008 - 06:00
Hi this didn't help me in my quest,
How can I allow the return traffic to come through the same interface? if I add an ip route 0.0.0.0 0.0.0.0 194.132.xxx.236 my setup works fine but the other subnets are affected obiviously because there is 2 default route configured
How can I get around this?
I have the following:
ip route 0.0.0.0 0.0.0.0 194.132.xxx.222 1
************************* INTERFACE *************************
interface e1
phy 100Mbits-FD
bridge vlan 30
interface e2
bridge vlan 92
phy 100Mbits-FD
interface e3
phy 100Mbits-FD
bridge vlan 70
interface e4
phy 100Mbits-FD
admin-shutdown
interface e5
phy 100Mbits-FD
bridge vlan 15
interface e6
admin-shutdown
interface e7
admin-shutdown
bridge vlan 11
interface e8
phy 100Mbits-FD
bridge vlan 11
!************************** CIRCUIT **************************
circuit VLAN30
redundancy
ip address 194.132.xxx.68 255.255.255.224
circuit VLAN92
redundancy
ip address 192.168.xxx.1 255.255.255.0
circuit VLAN70
redundancy
ip address 194.132.xxx.218 255.255.255.224
no redirects
circuit VLAN11
ip address 192.168.99.85 255.255.255.252
redundancy-protocol
circuit VLAN15
redundancy
ip address 194.132.xxx.226 255.255.255.240
Gilles Dufour Tue, 04/29/2008 - 06:29
  • Cisco Employee,
there is no mac-sticky equivalent on the CSS.
The only thing you can control is ecmp.
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/css11500series/v7.20/configuration/administration/guide/Protocol.html
"By default, the ingress path for a flow is the preferred egress path. This means that the preferred interface over which to reply to a client is the interface on which the CSS originally received the request from the client. "
For this to work, you need to add this 2nd route.
Gilles.
