Aironet 1100
Answered Question
Apr 24th, 2008
I am having trouble connecting an Aironet 1100. I was able to connect to via the web to do a software update on it. Now I am unable to connect to the Access now. I have flashing LED lights on the AIRONET 1100. The lights are flashing GREEN RED AMBER.
Correct Answer by Sushil Kumar Katre about 9 years 2 months ago
I am not able to understand this. Where is the DHCP server coming into picture?
Following are few of the following steps related to mode button -
Step 6 Press and hold the MODE button while you reconnect power to the access point.
Step 7 Hold the MODE button until the status LED turns red (approximately 20 to 30 seconds), and release the MODE button.
Step 8 Wait until the access point reboots as indicated by all LEDs turning green followed by the Status LED blinking green.
Step 9 After the access point reboots, you must reconfigure the access point by using the Web-browser interface or the CLI.
Are you allowing Step 8 and 9 to happen?
Once this is done the try to ping 10.0.0.1 which would be the APs IP.
Telnet to this IP usename Cisco password Cisco.
When you say you get the ping response, which IP address you get the response from?
I would suggest you to reload the IOS on the AP.
Please follow the setps given in the following link -
http://cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1038660
Please make sure that before renaming the IOS which is erquired [given in the link], on your TFTP server you go to Control Panel>Folder Options>View>Hide Extensions for known file types option is unchecked.
If not then uncheck this and then change the file name with watever is mentioned in the link.
I would also suggest you to use the following TFTP server -
http://tftpd32.jounin.net/tftpd32_download.html
-> Sushil
Boot the AP, leave it for 10 mins. Don't connect a PC to the AP.
There are three LEDs - Eternet status and radio. FIG - 22.2 - http://cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1058384
Refer to this link and try to match the LED status -
http://cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43trb.html#wp1047142
-> Sushil
Refer to the following link and based on the indicator signals you can figure out what's the problem.
-> Sushil
Overall Rating: 5 (6 ratings)
Correct Answer
Sushil Kumar Katre Thu, 04/24/2008 - 22:12
  • Gold, 750 points or more
-> Sushil
shaftymorgan Fri, 04/25/2008 - 00:12
What following link? I would like to know the indicator signals.
I am also having trouble with this product,
I reserved the MAC address on DHCP and still won't connect. After leaving it alone and trying the default address which I believe is 10.0.0.1
shaftymorgan Fri, 04/25/2008 - 01:19
Currently my indicator siganls are rolling green, red and amber.
What does this mean because I am checking the manual and it tells me nothing on the installation guide
Correct Answer
Sushil Kumar Katre Fri, 04/25/2008 - 01:25
-> Sushil
genesisenergyinc Fri, 04/25/2008 - 06:04
I have power cycled the 1100 and have not connected the ethernet cable to the AP. Now I have solid RED Ethernet and Status which (indicate ethernet failure during image recovery). Does this indicate that I have a bad AP and need to get a replacement. If not how can I fix this problem?
Correct Answer
Sushil Kumar Katre Fri, 04/25/2008 - 07:18
-> Sushil
genesisenergyinc Fri, 04/25/2008 - 11:01
Hi, Sushil
I have followed the instructions and I am not able to connect to the AP at all. I get ping responses but I am unable to connect. It seems the as if the ap is still the using the ip address that was given to it through dhcp. Any suggestion?
Correct Answer
Sushil Kumar Katre Fri, 04/25/2008 - 11:05
genesisenergyinc Fri, 04/25/2008 - 11:16
The ip address that dhcp assigned to the ap. This is after I have held the MODE for 30 sec.
Correct Answer
Sushil Kumar Katre Fri, 04/25/2008 - 11:22
