creating aliases
Apr 24th, 2008
Hello. I am trying to create interface aliases on 6509 switch here running 12.2 IOS. Here is an example: "alias interface ghost switchport access vlan 99". Created alias "ghost" runs fine on single interface but fails on interface range. According to Cisco it should work on interface range as well as on single one.
Am I missing something here? Is there a workaround for creating aliases for interface range? Thanks in advance.
Overall Rating: 5 (1 ratings)
20vek Sun, 04/27/2008 - 17:36
Thank you for your reply. Yes, it looks like a bug and I think that contextual help means that the same interface mode can be used for both interface and interface-range configuration. Thanks for the link it was very helpful and seems like it's what I was looking for.
