sundar.palaniappan Thu, 04/24/2008 - 15:47
Are you asking about assigning the context to a failover group? If it is then the command is 'join-failover-group ' under the context mode. This command should be supported in Version 8.x. If you have a different requirement could you clarify that.
Sundar
Gerard Gacusan Thu, 04/24/2008 - 20:21
got it...I need to enable multiple context first with this command, "mode multiple"
these are now available commands:
failover group 1
failover group 2
any basic config for A/A failover would be appreciated. Thanks ...
