Email Integration Manager and CAD
Answered Question
Apr 24th, 2008
How do we install the agent console in CAD (the email manager piece) after installing the email integration manager? is it a plug in like the CAD install - or is there a setting that we need to adjust.
We have all the other components of EIM set up, cant seem to locate this last piece.
It's not a plug-in. You simply set up the CAD Embedded Browser and configure the home page to be the URL of your EIM server. Something like http:///default.
There is a rumour that Cisco know how to add an Agent Management workflow to CAD so that a successful login to CAD will fire a workflow to automatically log the same agent into EIM. I don't know how it's done.
Geoff
Overall Rating: 5 (1 ratings)
Correct Answer
Geoff
lohjintiam Mon, 09/13/2010 - 00:30
Hi Geoff,
Do you know if this is already supported? Where agent login to CTIOS and automatically logs in (through workflow) to EIM/WIM within the integrated browser?
Thanks!
-JT-
