jackthumar Thu, 04/24/2008 - 19:55
Hi James,
The commands to change the SNMP community string is as follows.
Router(config)#no snmp-server community xxxx
where xxxx is current community string
Router(config)#snmp-server community yyyy
where yyyy is the new community string.
Pls follow the below mentioned link. It will give you a better understanding.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094aa4.shtml#modifysnmp
*Pls Rate if it Helps*
Rgs,
Jack
jlcarey1usa Fri, 04/25/2008 - 02:25
Jack,
Thanks. I was able to change the string and enter the new community name. I didn't realize it was so easy...
