Cisco 7513 router power consumption
Apr 24th, 2008
I need to check power comsumption on the cisco 7513 router that is running on our site now.
I googled the cisco web site but I could not find any information what I wanted
So does any one know the how to check the power consumption on the cisco 7500 router?
Leeyoungsoo Thu, 04/24/2008 - 19:40
Thanks for your reply
I tried that
But it was not incloud that current consumption power on the router.
Does one any idea about that?
t814687 Thu, 04/24/2008 - 19:50
is should show something like that:
PS1 +5V Current measured at 42.35 A (capacity 200 A)
PS1 +12V Current measured at 6.86 A (capacity 35 A)
PS1 -12V Current measured at 0.55 A (capacity 3 A)
PS1 output is 296 W
Leeyoungsoo Thu, 04/24/2008 - 22:48
Thanks for your quick reply!
I already see this output But it was not something that I want result.
Forexample,Catlayst6500 series have command to see the power comsumption that is "show power status all".
I need to see the current power comsumption
that like catalyst 6500 series.
Is there no way to check the power comsumption on the cisco 7513 router?
t814687 Fri, 04/25/2008 - 05:54
Not sure... maybe cisco TAC can help you, have you tried that?
